RealView problem
RealView problem
I just recently added a Quadro4 900xgl to my system, running SW 2004, but RealView is still not available (shaded out). I know this card is supported. Any Ideas?
Anyone can be Captain in a calm sea.
RE: RealView problem
Have you enabled the custom setting? The following is pulled from the nvidia driver site:-
http://www.nvidia.com/object/IO_20010601_3381.html
After installing driver, you may enable the custom setting from Start menu -> settings -> control panel -> display properties > select tab with NVIDIA product name -> additional properties -> Custom OpenGL application settings -> select SolidWorks from the pull down list.
cadmaniac
I would go back to the 4351 driver. I agree the 5303 is listed as approved for Real View, but it is in the dual monitors group. A possible "complication" you do not need if only using one monitor.
Have you tried the 4351 with the nVidia SW setting & Software OpenGL switch unchecked?
Are you able to try a different approved card?
Is your RAID array SCSI or ATA? I believe I remember reading somewhere(?) that SCSI can cause conflicts with SW, but may well be wrong, so don't quote me on that.
Have you tried creating a new part and assigning it a material like the shiny chrome stainless steel? I had problems with old parts not showing the realview graphics because they were created in SW2003. I had to remove or edit the material for the graphics to show...
Also if the part is already assigned a color, thats what you see...
Since nothing else is working for you (depending if you have tried everything in this thread and others) try a new profile and if you don't have admin privileges, get one that does.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
http://www.solidworks.com/pages/services/videocardtesting.html
