Send back objects/layers
Two questions:
1. When I send object back (Tools/Send back) in Model space, that does not influence VPORTS. Why? Any solution?
2. Does anybody know of a lisp that sends whole layer back?
thanks
thanks
RE: Send back objects/layers
1. I don't know the command send back... I use "_draworder"-> don't forget "regenall"
2. http://www.dotsoft.com/freestuff.htm, "DOBYLAYER.VLX"
It's a Better-than-nothing-Tool
regards, Lothar
1- It sounds like you need a REGENALL command to update all vports.
2- The following code gets a layer name and sends all objects in the layer to back. The code defines a new command named LBACK.
(defun c:lback(/ lname ss)
(setq lname (getstring "\n Layer name: "))
(setq ss (ssget "x" (list (cons 8 lname))))
(command "draworder" ss "" "")
(princ)
Farzad
