part names in assembly design trees not updating
Names of parts in assembly design trees do not update when I change the filenames of those parts. Anyone know how to make it update, either manually or automatically? I am still running v2003.. is this problem fixed in v2004?
Chris Montgomery
Mechanical Engineer
www.adaptivequipment.com
RE: part names in assembly design trees not updating
1. You open the part file and do a Save AS.
2. You do a Replace.
3. You edit component properties (slightly different issue, but could result in different names in the tree).
If you are changing file names in Windows outside the assembly and expecting SW to magically realize you have done this - ain't going to happen.
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There are only 10 types of people in the world - those who understand binary and those who don't.
Not a bug - it's a setting (even in SW03)
Tools\Options\System Options\External references\"Update component names when documents are replaced"
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
