Configuration for "simplified"
Well... I created a part and added fillet after all other features are created. So all fillets are bottom of the feature manager tree.
And then I added a configuration, 'simplified', that doesn't have fillet and suppressed all fillet.
For some reason, when I suppress fillets for "simplified" config., features that are above fillets in the feature manager tree give me errors.
I just don't understand why this is happening because fillets are added at the end...
Does anybody have an idea?
RE: Configuration for "simplified"
Unsuppress all the features and rollback each feature till you find the feature that is causing the failure.
One thing you might have is a problem from the beginning. Do a Ctrl-Q with everything unsuppressed. If it fails at the top it cause all the other features to follow.
A rebuild been each feature is not enough when building a part. You need to do a Crtl-Q every once in a while in the process of building a model. A Ctrl-Q goes to the top and rebuilds each sketch and feature it is associated too. You might have a problem at the top of your Tree and don't even know it. Then again you might not. If that's the case then you need to find the fillet or the features causing the issue and see if you can find a way around the problem.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
BTW: For Mate errors you work from the bottom up, because they are not parent-child and it is the LAST one added that causes the problems.
*** It's like the old joke... small plane - lost in fog near Seattle - gap in fog - pilot sees guy at open office window - - shouts "Where am I?" - answer "In an airplane." - pilot makes a 270 left - breaks out of the fog right on the approach path and excutes a perfect landing - passenger asks how - pilot says - "I asked for specific help - he gave a perfectly accurate but totally worthless answer so I knew it was the Microsoft office building 5 miles due north of the runway!"
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There are only 10 types of people in the world - those who understand binary and those who don't.
