SW 2004 Office - eDrawings not installed
My problem is that the eDrawings icon in the Office toolbar is grayed out and does nothing. All the other Office icons are ok. EDrawings is not listed under Addins. There also is no "Publish to eDrawings" under the File menu. Is there a way to re-install eDrawings Pro ?
I have installed Solidworks 2004 sp2.1 with Office on 4 machines from my Administrative image on the server. The image and installs are using MSI.
RE: SW 2004 Office - eDrawings not installed
When you DL that file, it is the full version just with a SP installed on it. You could DL the file, put it up on the server, and let your users copy and install the program from there.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
You do realize that the Help files are updated for each new SP of SW. But they are not included in the initial DL of SW? You should always at least update your Help file.
Scott Baugh, CSWP
FAQ731-376
