Two Blocked
Two Blocked
In the days when ships were wood and men were steel the condition of two blocks being pulled tightly together in a block and tackle was called being "two blocked".
When I worked in a seagoing steam plant, the condition of a packing gland being tight against a valve body assumed the old term. People didn't understand the reference and started saying that valves were "tube locked", "Too locked", etc.
Anyone have other terms that lazy people have evolved from a clear reference to a garbled mess?
David
David
RE: Two Blocked
No, it appears "brine" had become a generic for a coolant and in this case, mono-ethlene glycol solution.
RE: Two Blocked
Knew an electrical inspector who would always call them "condominimums".
RE: Two Blocked
irregardless
orientated
RE: Two Blocked
We had a client who used the same term. He built them.
We had a problem in not laughing when he said it. Bad for business!!!
Buy a dictionary, keep it nearby and USE it. Webster's New World Dictionary of American English is recommended, and Webster's Collegiate Dictionary.
RE: Two Blocked
Cheers
Greg Locock
RE: Two Blocked
v., -tat·ed, -tat·ing, -tates.
v.tr.
To orient: “He . . . stood for a moment, orientating himself exactly in the light of his knowledge” (John le Carré).
v.intr.
To face or turn to the east.
ir·re·gard·less (ir'i-gärd'lis)
adv. Nonstandard.
Regardless.
[Probably blend of IRRESPECTIVE and REGARDLESS.]
USAGE NOTE Irregardless is a word that many mistakenly believe to be correct usage in formal style, when in fact it is used chiefly in nonstandard speech or casual writing. Coined in the United States in the early 20th century, it has met with a blizzard of condemnation for being an improper yoking of irrespective and regardless and for the logical absurdity of combining the negative ir– prefix and –less suffix in a single term. Although one might reasonably argue that it is no different from words with redundant affixes like debone and unravel, it has been considered a blunder for decades and will probably continue to be so.
RE: Two Blocked
Quantitation
TTFN
RE: Two Blocked
quan·ti·tate (kwon'ti-tat')
tr.v., -tat·ed, -tat·ing, -tates.
To determine or measure the quantity of.
[Back-formation from QUANTITATIVE (ANALYSIS).]
quan'ti·ta'tion n.
RE: Two Blocked
I've never seen "Quantitation" before, and it is a bit ugly, but my first guess as to its meaning was spot on. One of the objectives of written language is the communication of ideas and concepts, surely this word facilitates that aim?
Cheers
Greg Locock
RE: Two Blocked
Brian
RE: Two Blocked
From Dictionary.com:
median strip
n. Eastern, Midwestern, & Southern U.S.
The dividing area, either paved or landscaped, between opposing lanes of traffic on some highways. Also called median, also called regionally boulevard, mall, medial strip, meridian, neutral ground.
RE: Two Blocked
I guess that's progress, a longer word that means the same as an existing word. Go Scrabble.
RE: Two Blocked
I sad to say that I think it might also have been invented by engineers looking for a more officious word to use in reports.
TTFN
RE: Two Blocked
Your reasons may very well be correct IRstuff.
<sarcasm>
So let's just reinvent the wheel (with a bigger one that does the same thing), and reduce efficiency in communication at the same time. Now that's good enginnering????
</sarcasm>
I have no problem with the creation of new words to encapsulate a meaning when such a word does not already exists. For example: grammatify (verb, to make grammatically correct). There is no such word, nor (at least to my knowledge) is there a word that means the same thing.
But to create a redundant word (ie orientate) simply does not make sense.
My fear, is that it's just plain easier to make up a new word, than to take the time to learn the language. That's laziness.
RE: Two Blocked
In one report writing class we were instructed that officious word use is not only superfluous but possibly confusing. Making up words with more syllables or misusing a longer word where a shorter one will do does not clarify. Officious was not the term applied in this case rather it was unnecessarily flowery words as in coloration which is a valid word but oversused where the word color could describe better.
I have always objected to the use of the word diametrically. It just sounds way overdone and thought people using it were wrong and should be saying diametrally so I just looked it up and stand corrected.
I do bristle slightly when people say radiuses instead of radii which rolls of the tongue much cleaner. Oh darn. Looked it up, and either is ok.
Jesus is THE life,
Leonard
RE: Two Blocked
I have heard the expression many times and always thought it was tube-locked?
Two blocked never even came into my mind... but makes sense now that I know the origin.
RE: Two Blocked
TTFN
RE: Two Blocked
"After the upgradation of my monitor I am now able to discern between mauve and maroon."
That's a real stretch!
RE: Two Blocked
RE: Two Blocked
[you're] in detention until you use [your] dictionary.
RE: Two Blocked
Guilty as charged! I was trying so hard not to screw up. I guess this forum is making me a literary paranoid. (or literally paranoid? I don't think either one is right AGGHH!!!)
RE: Two Blocked
or even possibly, a literate paranoid?
TTFN
RE: Two Blocked
My dictionary (The Penguin Macquarie) makes a distinction:
"Orient" is primarily a noun relating to "The East", as in "The Orient". It can also be a verb meaning "to align to face to the east".
When you need the more general verb meaning "to adjust with relation to", "orientate" is the only form offered.
Of course, it is possible that the Macquarie is just reflecting current (Australian) usage rather than etymological exactitude (now THERE'S a phrase guaranteed to get a few people checking their dictionaries to see whether I used the right words, and spelt them correctly!), but if it's in the dictionary, it's good enough for me!
On the other hand, my "Oxford Pocket Fowler's" says both are used with identical meaning as verbs, and "there is no meaningful criterion for choosing between them, except that 'orient' is shorter and therefor less cumbersome in some contexts".
RE: Two Blocked
I guess this term has evolved more than most in the last (almost) 20 years.
David
RE: Two Blocked
RE: Two Blocked
1. Past participle of the verb spell (common weak participle for words with Germanic origins)
2. Abbreviated (possibly colloquial) for spelter (alloy)
3. Archaic wheat-like grain, common in Europe during Bronze age and earlier
Good Luck
johnwm
RE: Two Blocked
RE: Two Blocked
RE: Two Blocked
Good Luck
johnwm
RE: Two Blocked
You didn't think I would DARE to post on this forum without rigorously double-checking my spelling first, did you?! (The free download of "iespell" from www.iespell.com is a real life-saver here! It allows you to conduct an on-line spell check in any Windows text-entry box.)
I reside in Australia, so I prefer to stay with British spelling and pronunciation over American forms. I use the Macquarie Dictionary and the Oxford Fowler's as my "bibles". Both permit either "spelt" or "spelled", but note that "spelt" is generally preferred in British and Australian English, and "spelled" is more common in American English.
