ultra small dc regulator
developing a small dc regulator im trying to get 110 ac and then get 5vdc, @ 1A what do you think about rectify directly from 110vac, then using a SCR and a microcontroller to perform phase control, then a LC filter and at last a lm 5vdc regulator, i think it seems easy to develop and a small choice.
thankx for any comment,
killa
killa
RE: ultra small dc regulator
Switching power supplies are designed every day for your application. I was involved with a "wall wart" design. 110VAC to 5vdc @ 1.2 amp - it was a switcher with galvanic and optical isolation. Search the web for switching power supply theory...
power supply is an option but frequently involves a transformer.
its designed to charge a batt and to feed a mcu maximum 700mA.
any other comment will be of great help.
thankx
killa
For lower current you can use series capacitor, for 110V 60Hz you need 2.4 microF for each 100 mA.
<nbucska@pcperipherals.com>
