DIN Rail Mount Control Transformers
Does anyone know of a manufacturer of DIN rail mount control transformers. So far I can only find Hammond -
http://www.hammondpowersolutions.com/docs/product/htp02section1dinrail.pdf
Unfortunately, they do not have a 208V or 220V to 120V 50/60 Hz 75VA transformer.
Steve Smith, C.I.D.
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
RE: DIN Rail Mount Control Transformers
You may be stuck with ‘group F’ or ‘group G’ transformers like
http://www.microntransformers.com/pdf/micron_domestic_webcat.pdf
You might contact CPT manufacturers and see if they know of an adapter/base for DIN-rail mount of their products. But, isn’t 3½ pounds a bit much for DIN rail?
<nbucska@pcperipherals.com>
We are trying to make all components rail mounted to allow quick assembly & easy replacement for different options.
does offer a 220 to 120 VAC VAC 75VA DIN rail mount control transformer. Type PTD-AA is the series - PTD75MQMJ is the part number.
240/480V : 120V
230/460V : 115V
220/440V : 110V
Steve Smith, C.I.D.
Product Engineer
www.stacoenergy.com
I agree. So what is the problem?
a lot of input variation.
What quantities are you looking at? Hammond can supply a 208/120 DIN rail mount in quantity.
This is for a new product so AMU is just a guess. We will probably buy only 25-100 pieces at first and go from there.
I've sent a request to Hammond on availability of a 208/120 transformer (last week) and still haven't received a reply.
