SAE J 429 Grade 8 Bolts for piping applications
Are SAE J 429 Grade 8 bolts acceptable for use in a piping system built to B31.3. Does B31.3 recognize Grade 8 bolts?
RE: SAE J 429 Grade 8 Bolts for piping applications
Rather you need ASTM A193-B7 or B7M studs with ASTM A194-2H or 2HM heavy hex nuts. The "B7M" and "2HM" alternatives conform to the NACE MR-01-75 specification.
The ANSI B31.3 takes into consideration the stress level of bolting and material under various conditions, not only load and temperature. Therefore Charpy Notch Toughness and SCC issues, which directly relate to material considerations, come into play.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
