Steer by Wire
Steer by Wire
I have recently read that GM are developing and seeking approval for a steer by wire system for road cars.
I have no experience in the specific field of electronic control systems as applied to road cars.
I wonder if anyone can tell me what great leap forward in technology guarantees that such a system would not be susceptible to the same rate of failure as any other system found on a family car?
It must be appreciated that even a relatively small, momentary deviation in a steering system can be catastrophic.
Here in the UK we have an annual compulsory safety check for all cars over 3 years old. I doubt wether a potential fault in a sensor or servo would be as easily detected as a worn mechanical link.
Pete.
Pete.
RE: Steer by Wire
Most modern aircraft are "fly-by-wire" now. Automotive accelerator pedals have been increasingly connected to the engine ECU rather than to a throttle cable for some time now as well. The major safety enablers for X-by-wire systems are advanced diagnostic and prognostic capabilities.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
