Hardening of 316 St/St
A couple of years ago I saw some components (Valve Ball and Seats) which had undergone a solution treatment which Increased the Surface Hardness of the components and turned the parts almost black in colour.
Whatever the treatment was it did not involve too high a temperature as it was carried out on finished components. The process only changes a few microns from the surface and allows 316 to run against 316 without picking up.
If it helps I seem to recall the process had a German sounding name....although I might be wrong here.
Can anyone point me in the right direction here as to what the process was?
RE: Hardening of 316 St/St
(I think it was a Kolene process or similar. Possibly QPQ?)
nick
www.kolsterising.bodycote.com
Maybe use the latter over the former??
