SF6 dielectric strength
I am searching for information in relation to the dielectric strength of SF6 in kV/mm. Please suggest publications that have the answer or tell me the answer. Thank you.
RE: SF6 dielectric strength
Suggestion: Visit
http://www.usbr.gov/power/data/fist/fist5_9/5_9_1.htm
for:
1.1.2. Dielectric Strength. Its dielectric strength is 2 to 3 times that of standard air and has high thermal stability. The dielectric increases with increasing pressure and at 3 atmospheres, the dielectric strength is roughly equivalent to insulating oil. These properties make it useful in gas-insulated buses and compartments which contain electrical switchgear components.
https://gpxsvr5.np.edu.sg/apps/lib/special/npstaffpub.nsf/0/6920072362d4b290c825676e00056c52?OpenDocument
http://www.fluorocarbons.org/frame.htm?applications/others/h_transfluid/main_appli/main.htm
(contact for dielectrical strength)
etc. for more info
An old standard reference is Yew, Matheson Gas Data Book, McGraw-Hill, 2001.
Suggestion: Reference:
Donald G. Fink, H. Wayne Beaty "Standard Handbook for Electrical Engineers," 13th Edition, McGraw-Hill, Inc., 1993,
Page 4-131 Insulated Gases
Figure 4-54 Pressure spacing dependence of dielectric strength of gases (Paschen's curves) on page 4-134
