Alignment text size
Alignment text size
Alignment text size
I know this maybe a pretty easy question but i can't figure out how to change my alignment stations font sizes in autodesk land development.
Can anyone help on how to set the text sizes ?
Thanks.
RE: Alignment text size
I am not sure about you certain app, but have you tried double-clicking the text or selecting it first then type in "change". I hope this helps.
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
I hope this helps.
Alignment stations are inserted into the drawing with whatever the current text style is. So, if you change your text to the desired style before you create your labels, you should be able to get the results you are looking for.
