HIC TEST ..Different result for the same Heat Number?
I noticed failures for some heat number ,,,and when we re-rest another plate from the the same heat ...some times it pass the test!!
Can we have different result for the same heat number for HIC test.
we used sloution A and the same procedure !!! Can i have answer for my concer and explination about how these result can be different from test to another
RE: HIC TEST ..Different result for the same Heat Number?
it is strange for me ...i could not understand this...any explination???
Suggest you examine the failures to see what the HIC damage is associated, i.e. is it sulphide inclusions, or microstructural variation, these will influence the test result.
The level of residual stress you have imparted into the item in forming plate to pipe will also have a detrimental effect on the HIC resistance of the material.
