UNKNOWN COMPONENT
UNKNOWN COMPONENT
UNKNOWN COMPONENT
Can anyone help me to identify this component?:
Si VN 0660 9246
It's a three terminal device in a TO-92 package.
Thanks for your help!!
RE: UNKNOWN COMPONENT
Appears to possibly be a Supertex VN0660N3 N-Channel enhancement mode vertical channel VMOS FET in a TO-92 plastic package made in the 46th week of 1992. This part is listed as obsolete.
The "Si" is probably a "St"
Datasheet:  http://www.supertex.com/pdf/datasheets/VN0660.pdf
Supertex website indicates a VN2460N3 may be a replacement. You will need to research this more completely.
Datasheet: http://www.supertex.com/pdf/datasheets/VN2460.pdf
