Fasteners for Treated Wood
I understand that the treated wood in our area is treated now with either (Alkaline Copper Quat) ACQ-C and ACQ-D, or(Copper Azole)CBA-A and CA-B. What type of nails, screws and bolts should we be using?
RE: Fasteners for Treated Wood
See:
http://www.strongtie.com/ftp/bulletins/T-PTWOOD04.pdf
http://www.taunton.com/finehomebuilding/pages/h00127.asp
jheidt2543 indicated to check:
The February 9, 2004 ENR magazine has an article on page 17, "Industry Sounds Warnings Over Corrosive Effect on Steel".
YorkWrap™ Non-adhesive Polymeric Isolation Tape* is a flexible, 20 ml. thick PVC membrane designed to isolate ACQ pressure treated lumber from galvanized metals.
see at: http:/
It is very important to prevent standing water. There are a number of fastner systems that don't go through the deck boards, but grip from the sides. These should have an advantage.
Check out http://www.wolmanizedwood.com/fasteners.shtml
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
