Conductivity ammonia
Hello!
Who of you knows the conductivity of liquid ammonia (mS/cm)? I don't find anything on the web...It's (I am) unbelievable.
I need it for the decision whether a certain level switch can be used.
Kind regards
RE: Conductivity ammonia
the anhydrous form is a dielectric
Sensitivity to Static Charge:
Liquefied ammonia will not accumulate static charge, since the electrical conductivity is high.
Electrical Conductivity:
1.3 X 10(7) pS/m (- 79 deg C ) (32); 3 X 10(9) pS/m (commercial) (-35 deg C) (31)
Minimum Ignition Energy:
680 millijoules (32)
The googled info above is from
http://www.intox.org/databank/documents/chemical/ammonia/cie48.htm
I am not familiar with the firm however so you will need confirmation, and probably a few more data points.
Cheers
Steve
in Langes hand book the resistivity of anhydrous ammonia at -79 oC is 1.3(10-7) ohm-1/cm (this aggres with above).
Its dielectric constant is 22.4.
if I have my unit conversions correct,
at -79 oC the resistivity is 0.76 (10^7) ohm-cm
at -36 oC the resistivity is 0.33(10^5) ohm-cm
this is a pretty high resistivity. as soon as it picks up water, it will plumet.
VIRK:
30+yrs in engineering convinced me that not every problem
deserves a solution -- often it is better to design around
it.
I would use permanent magnet activated Reed-switch,
e.g. in the middle of a long heatshrink tube.( The magnet
would be mounted on a float)
<nbucska@pcperipherals.com>
no disagreement about advice regarding avoidance of certain instrument types in this service, but that is not the question
agreed, truer words have not been spoken...
Thank you all.
The measuring method (conductivity) does not seem to be suitable. We haven chosen for liquiphant (stem fork) method.
Kind regards
Virk
