Appropriate Puck Test Limit??
we have a Trumpf 2200 watt continuous wave CO2 laser we use to machine sheet metal. Occasionally, it is necessary to perform a laser power output calibration, or Puck Test (labeled so because the laser power probe resembles a hockey puck).
When the machine was brand-new, output readings ranged between 2.2 and 2.4 (Kilowatts over 10 seconds). Now, five years later, despite regular maintenance and proper operation, our probe is reading between 1.9 and 2.1 (kW over 10 sec).
My question is this: Does anyone know what output we should be seeing for a 2200 watt laser? What reading should we be able to attain and aim for when we do a Puck Test?
CoffeeMan
CoffeeMan
RE: Appropriate Puck Test Limit??
Another source of error:
Has the probe and meter been calibrated and inspected lately? Possible probe damage from too high of an energy density could cause power readings to be too low.
-Pete
As Pete says above, you have to determine if your test instrument is still working correctly.
Five years is long enough that your laser may need more than "regular maintenance". Part of the question is: Does it cut well? Is the beam quality still good?
Some lasers need to be overhauled or have blowers replaced to avoiid catastrophic failure- I have no clue as the your machine's requirements.
What does the factory service department suggest?
regards
Jay
Jay Maechtlen
