I Beam equivalent of wood 8" X 8"
I am rebuilding a 32' x 48' barn.  It originally had 8 x 8 beams supported approx. every 10 feet for the 32' width.  It then had 6" log "joists" 12' long, 2' OC spanning the * x 8's.  The 6" logs were topped with wide planks that were 1 1/2 " thick.  The sides of the barn were 10' tall, and the roof had a 6/12 pitch.  The barn would be filled from floor to ceiling with hay, hay bales in later years, and stood for 160 years.  Does anyone have experience with a similar senario?  What I beam would replace an 8 x 8 and have a similer capacity?  The barn burned down many years ago and there is nothing left to measure, the 8 x 8's may have been 10 x 10's, but not any larger than that.
RE: I Beam equivalent of wood 8" X 8"
I think you should hire a competent structural engineer to do your design. He/she will have knowledge of the local codes. Even if you get the beam size from someone, you still will need a permit and inspection before the insurance co. will write apolicy on it.
