Can not Hide edges in a broken out section
I've seen this discussed twice in this forum after doing a keyword search, but haven't found the exact solution to my problem.
I have a hollow cylinder that I've modeled with solid threads down the ID. The threads are rotated boss of a thread tooth sketch, then linearly patterned down the bore so as to give me a visual on how much room between parts fitting inside the bore I can afford with a particular thread pitch.
In the drawing I view the cylider on its side (ie perpendicular to the bore) and make a broken-out section view. I then try to hide the edges of the threads that I'm looking at, but they don't dissappear even after attempts to reload or redraw the part. Re-clicking on the same line only allows me to "show edge". I've also tried "un-breaking" the view and showing all the lines, hiding the lines in question, THEN re-break the view and still nothing. The only thing I've gotten to partically work is by re-booting my computer and then having the ability to hide only SOME of the lines. This is infinitely frustrating, especially since I have no problem hiding the edges in a full blown section view. I've also tried this on other similar parts with the same results. I'm at my wits end. Please Help.
RE: Can not Hide edges in a broken out section
Or
Change the offending line colour to white.
Or
Don't use "thread" in the model, use min dia & cosmetic thread.
FAQ559-863
I don't know about ANSI standards, but try to follow ISO standards for drawing views is sometimes painful.
I think, until now, the best way is to create configurations as CorBlimeyLimey said: that means hard work for such a "small" improvement in the drawing. But the tip for changing the color to white seems to be a simple alternative. I don't know if they don't show up in printed drawings. I'll give it a try! If they don't show up in printed drawings, it's a nice tip!
The thing that really boogles me, is I can hide the edge in a section view. This would tend to mean that I'm not selecting edges on top of the edge I want that have been removed by the section cut. But this won't work for a broken-section view. It's starting to look like a quirk in the programming....
FAQ559-863
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
