New Parameter UI window size
In Pro/E 2001 on Windows 2000 Professional OS, does anyone know how to resize the New Parameter UI window so that more parameters are visible? Simply dragging the bottom edge of the window only gives more "gray space" around the buttons, not the parameter editing area.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
RE: New Parameter UI window size
The only thing I have found is in the config.pro under USER INTERFACE there is a new_parameter_ui.
Selecting NO will not show the window, but leave the parameters in the menu list, but again this doesn't seem to have many more showing.
There is nothing on PTC's knowledge base either.
This surely must be easily changeable, why not request this from PTC.
We have 21" monitors and stretching the window to the full height of the screen still only shows 15 parameters.
Hope this helps.
maybe only a drafter
but the best user at this company!
Thanks for the reply, you have summarized my experience. Bummer.
Best regards,
Matthew Ian Loew
Branch Rickey
