2000 kva emergency generator
Does anybody has experience with 2000 kw diesel generators by Kohler? How they may be compared with Caterpillar or Cummins units of the same size in reliability and service for mission critical facilities?
Thank you,
Bob
Thank you,
Bob
RE: 2000 kva emergency generator
References:
1.
http://www.marketresearch.com/map/prod/848345.html
for: $5950 a copy of North American Generator Set Markets
2.
http://www.epa.gov/otaq/regs/nonroad/equip-hd/nr-ria.pdf
for: Table 2.10
3. etc.
The genset producer is far less important than details clearly stated in procurement verbiage. No offense is meant, but the term “mission critical” is meaningless unless precisely defined in specifications and standards.
Acceptable specs come from years of experience and ‘lessons learned’ through dealing with similar equipment in similar settings. Expectations of reliability, maintainability and electrical capability/compatibility will likely not be met unless very specific details are addressed before (and after) bid award. Equally important and deserving significant attention are the switchgear and engine controls that support the generator.
It is essentially a sure bet that unless detailed in writing, your perceptions and what a vendor actually provides will be widely different, and may yield a very upset facility operator that has to live with the system you provided for decades.
As for Kohler, I think their reputation is at least equal to Caterpillar.
I believe Allison may still offer a two-stroke diesel that may be appropriate for a true emergency generator.
If you have an engine-generator that is "mission-critical", you'd better buy at least two and hope that one starts, no matter what brand you buy. And start them once a week.
Some of things you can do to make a final decision include:
1. Take a tour of their factory and get a feel of how they make their units.
2. Ask few users of the similar units who has them for more than 3-5 years.
3.Do not forget to specify a good alternator.
I agree with dpc and busbar.
Reliability of a mission critical system depends on so many things.
As for the 2000KW units, I've had experience with 2 of them at one hospital. As a third party testing company we loadbanked the units. There was one failure with an oil line on one of the units. But with caterpillar service personel on site it was fixed/retested that day and no problem were reported since. That was 2 year ago.
