400 Hz Ground Current Induction
I am working on a task to investigate ground currents within a 100 kVA 60 to 400 Hz rotary conversion system.
Installation is very standard, 4" aluminum conduit with 3 phase & 1 equipment grounding conductor. Current measured on the equipment grounding conductor is approximately 15% of phase currents at full load.
I am looking for technical resources to review this installation.
