Turning off the spin center in Wildfire
Is there a way to turn off that huge red square and annoying red lines that pop up when you spin the model?  I've looked high and low, and can't find the config option anywhere!
Danka,
An
RE: Turning off the spin center in Wildfire
On 2001 it is in UTILITIES-->ENVIROMENT and then uncheck SPIN CENTRE.
Hope this helps.
maybe only a drafter
but the best user at this company!
Thanks for the help.  But what about on Wildfire?  Even if you turn off the 'spin center', you still get that new spin icon when you start spinning the model.
