UPPER BAINITE - LOWER BAINITE
What is the most appropriate method for differentiating upper bainite from lower bainite ? Is light microscopy able to do it via special etching such as SMB (sodium metabisulfite) and / or picral ? Is the use of polarizing filters and sensitive-tint plate going to help ? Material to be checked is 4340 liquid quenched and tempered.
Thank you.
Thank you.
RE: UPPER BAINITE - LOWER BAINITE
lower and upper bainite are distinguishable by the size of the structure. Use a good brightfield scope, a 550nm (green) filter might help bring the contrast out, Nital etch.
nick
I also think that the lower bainite will be the finer structure.
nick
Picral is also a reccomended etch from Metals handbook 9th edition.
nick
http://www.metallograf.de/start-eng.htm
Interesting web site - I better brush up on my German.
The webmaster appears to translating more everytime I've visited the site.
They respond in English so there is hope.
unclesyd
As for lower bainite, it would be more regular needlelike shape. The temp for lower bainite to form is around 200-300 deg C.
