Anchor Rods for Canopy Foundation
Drawings on a job I am inspecting call for 1 1/2" x 3 ft long anchor bolts (should have been specified as anchor rods) to be embedded in a reinforced concrete foundation, to support a gasoline station canopy
Anyway, the contractor is using bolts, correctly sized in diameter and length, but instead of the standard hook end, the anchor rods have ends that are bolt heads.
Is this an OK equivalent?
RE: Anchor Rods for Canopy Foundation
