How to use usersubroutine(UMAT) through Abaqus/CAE?
Dear all,
I'm a new guy for using ABAQUS. Now, I'm use ABAQUS v6.4. Do you know how I can add usersubroutine of UMAT by using ABAQUS/CAE?
Thank you very much
Maysar
RE: How to use usersubroutine(UMAT) through Abaqus/CAE?
User subroutines are a separate piece of fortran coding which can be added to the end of an input deck or added to the command line when you run the job. You don't add it in CAE though you refer to it in the particular line of input data by adding ,user
corus
Thank you Corus..
Could you explain me more details? or where can I find the steps of using usersubroutine?
Thank you
Mayasar
Maysarr,
With all due respect, I doubt that it is in any way possible to explain to you - within the scope of this forum - how to develop a UMAT subroutine, unless of course you have a pre-written UMAT that you just need to add in. And even in this case, the best - and probably only - place to look for reference, including how to merge in the UMAT, is the ABAQUS reference manual.
Best of luck,
-- drej --
