Metal Alloy For Construction of Duplexer, Diplexer or Cavities
Dear Members
I need help about the alloy composition for construction of Diplexer and Cavities for microwave equipments. I constructed two diplexers using brass alloy, but I know that the correct option is aluminium with copper or another metal.
If someone know the correct composition, please send me a information.
Marcos Olandoski
Marcos Olandoski
RE: Metal Alloy For Construction of Duplexer, Diplexer or Cavities
Then the problem is the minimum total costs
Marcos Olandoski
The attributes:
Prescription TCE, low thermal resistance
Easily machined, pressed or molded to high precision
Low cost plating options.
I can not remember the company making these statements however.
Use silver plated aLuminnum for both housing & resonators. The cheapest way to manufacture the diplexer is to cast both housing & resonators in one piece.
Follow this spec to silver plate your aluminum housing:
Electroless Nickel per AMS 2405B (200-250 micro-inch), then Copper per MIL-C-14550B (50-100 micro-inch) then silver plated per QQ-S-365D, type I (300-450 micro-inch).
Hope this will help.
Krytar
I would like to know more about pim. Everybody says that you could not use nickel. Exactly in what application that is important?
We finished the development of diplexer for 400 MHz, 600 MHz and 900 MHz. Now we are working in diplexer for 1,2 and 2,4 GHz. We used aluminium and silver plate as specified by Krytar. The results were very good.
Olandoski
I'm glad that you use my method.
Using silver plated aluminum to filter resonators, trnasmission line was downplayed by Bob Wenzel, a filter guru, but we had proven it worked well.
Some of our filters/ multiplexers (penta, quadra, tri, and diplexers) are functioning up there in at least 8 satellites.
Krytar
htt
Olandoski
