Problem designing a wheel in Solidworks
I am new to solidworks, never used it before, and this problem is probably easy but please bear with me. I'm creating a wheel for a design project in Solidworks 2001. I have basically got a rim with a solid disk in the middle. I don't know how to create spokes for example. Any helpful tips or suggestions would be appreciated.
RE: Problem designing a wheel in Solidworks
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
You could also have a really short piece of a line segment out there.
The easiest way I can tell you to find it is edit the sketch, without selecting a command draw a box around part of the geometry. If you see a grip that seems out of place that is probably your problem.
You can use Tools\Sketch Tools\"Check sketch for feature" this will let you know what is wrong with your sketch.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
