Reduce reflection on water surface
I am a novice at infrared imaging, and I'm imaging water surfaces with an IR camera. I'd like to reduce the amount of reflection from things such as overhead lights, sun, etc.... I have successfully reduced it by covering the whole system with a dark fabric, but I'd like to know if there is a better way.
The reflection seems to be just a (thermal) mirror image of what is above the water surface (including the camera itself).
Any ideas?
Any ideas?
RE: Reduce reflection on water surface
Water is also increasingly reflective the farther you are from 0ยบ angle of incidence (normal).
TTFN
I hope you guys don't mind if I hang around here and continue to "pick your brain" while I get up to speed with IR technology.
Thanks again.
<nbucska@pcperipherals.com>
