Referencing VB userforms from Excel cell
Hey guys,
I'm trying to write some simple code that will allow the userform that's opened by a single method to be altered depending on the value in an excel cell.
In the base case, cell A1 in Sheet1 has the value "Userform1". With in the method code I now need to transform this cell reference into a format that is compatible with the "Show" method.
Any help would be welcomed with open arms.
Craig
Craig
RE: Referencing VB userforms from Excel cell
Sub Excelform()
Select Case Cells(1, 1)
Case "userform1"
UserForm1.Show
Case "userform2"
UserForm2.Show
Case "userform3"
UserForm3.Show
End Select
End Sub
i hope this will solve ur problem
Private Sub Worksheet_Change(ByVal Target As Range)
If Target.Row = 1 And Target.Column = 1 Then
Select Case Target
Case "userform1"
UserForm1.Show
Case "userform2"
UserForm2.Show
Case "userform3"
UserForm3.Show
End Select
Else
UserForm1.Hide
UserForm2.Hide
UserForm3.Hide
End If
End Sub
shakildor
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
Select Case Target
Case "userform1"
UserForm1.Show
Case "userform2"
UserForm2.Show
Case "userform3"
UserForm3.Show
End Select
Else
UserForm1.Hide
UserForm2.Hide
UserForm3.Hide
End If
End Sub
