Open solidworks assembly in solidedge
hello ,
is it possible to open solidworks assembly (*.sldasm) in solidedge ?
Or do i convert the assembly to a step format first ?
RE: Open solidworks assembly in solidedge
Other formats that can be opened in SE (iges, sat, ...) should also be tried if the results you get are not satisfying.
NB: Look at the import options in SE. they can be very helpful. Check also the export options in SW.
In solidworks i can open a solid edge assembly with extension : *.asm
Does solid edge support also a *.slasm extension ?
