Steel Flywheel - Ring Gear Interference Fit
I am currently working on the design of a steel flywheel for a customer to replace the dual mass flywheel that is already on their vehicle.
Does anyone know what a 'standard' interference fit for holding a ring gear onto a steel flywheel should be?
Many thanks in advance for your help Guys!
RE: Steel Flywheel - Ring Gear Interference Fit
Rod
Once again many thanks!
