Very old 2 speed AEG ac motor
Gentlemen
I am looking for details on a very old 2 speed AEG ac induction motor I've come across at a customers.
Details:
make: AEG
model number : AM280 MZ 4/2 Y11
power: 72/82 KW 127/137 Amps
speed: 1435/2980 rpm
This motor is very old, and seems to use a star delta type contactor arangement.
Any help appreciated.
Nigel
Details:
make: AEG
Nigel
RE: Very old 2 speed AEG ac motor
Here are some diagrams...
http://www.firstelectricmotor.com/motor_connections.htm
http://www.usmotors.com/products/ProFacts/1-105.htm
http://www.ab.com/industrialcontrols/products/nema_motor_control/contactors_starters_overload/pdf/520-wiring.pdf
Try a search on the term "Dahlander-Connection"
I'm afraid I have a very "electronic" bias, and I'm just trying to help my customer, as the on site engineer is somewhat of a "mate".
The speed change is by "altering" the windings as suggested above, I only listed star/delta as thats the one I see most of that doesnt involve electronic speed control, ( I know star/delta isnt really speed control, just a way of starting).
I will check out the links above.
The on site engineer has gotten the motor working, but was unable to find anyone with any knowledge of this system.
The problem he now has is when changing from the faster speed to the slower speed he gets "objection" from the motor, ( noise, current draw etc), suggesting that he needs a time delay of some kind, so as not to re-apply power until the slow speed has been reached, or dropped below.
Again many thanks gentlemen, I think I'm going to like this site.
Best wishes
Nigel
Arvor engineer
From the description of the motor, and with some interpretation of the motor part number, your motor appears to be designed for star connection only but is designed to operate as either a two pole or four-pole machine, thus effecting the change in speed. The relatively constant current for both high and low speed mode indicates that the motor is a constant horsepower type, whether in high or low speed mode.
I'll have a look in the excellent Brook Hansen 'little red book' when I get back to work on Monday. The book has dozens of motor interconnection diagrams and other useful information. It only costs £10 and is available mail-order. It is well worth investing in a copy, particularly if you are playing with motors with incomplete details and are trying to suss them out.
http://www.brookcrompton.com/tech-guides.htm
When changing from high speed back to low speed, the motor is momentarily acting as an induction generator until it drops below the 1500rpm synchronous speed for a 4-pole machine. During this period it will be dumping energy back in to the supply at a high and uncontrolled rate causing the current surge and noise you observed. A short delay will smooth things out by allowing it to coast down naturally prior to energising the low speed winding.
Start each new day with a smile.
Get it over with.
High speed ( 2 poles) connect as 1 Delta. Feed motor terminals 6,4&5; L1toT6, L2toT4, L3toT5 leave motor terminals 1,2,3 open.
Low speed ( 4 poles) connect as 2 Wye. Feed motor terminals 1,2&3; L1toT1, L2toT2, L3toT3, terminals 4,5&6 are connected together (neutral)
The phase sequence is very important, if changed the motor will reverse rotation with the speed change and will trip the overcurrent relay.
L1 means power line 1, etc
T1 means motor terminal 1, etc.
http://www.sea.siemens.com/contrlbu/upld/files/p41-46.pdf
for 2-speed motor-winding connections
Figure 11 on page 6 looks promising. Just how aolalde described it.
Get it over with.
I will contact the company first thing Monday morning.
I am suprised by, and very pleased with all the help and suggestions.
Scotty, where are you in the UK ?
Best wishes
Nigel
Arvor engineer
I'm a Geordie living in exile in Teesside, gradually working my way home to God's Country after a spell in the south. Where are you?
Get it over with.
I'm quite lucky though, get to travel all over, was even in the states before christmas, Lawrenceburgh, near nashville.
Strange place though, they make Jack Daniels there, but you cant drink it !, dry town or something like that.
Best wishes
Nigel
Arvor engineer
