Interference for metal-polyacetal assembly
Hi friends,
I have had difficulties to specify right interference for assembly of a metalic bear into a hole of a polyacetal part (Diam. 2,60). Could anyone help me?? I need a fix fit.
Thanks in advance,
Yochio
Thanks in advance,
Yochio
RE: Interference for metal-polyacetal assembly
I assume your dimensions are metric.
A 1-3% interferance fit will give a nice tight joint. A metal clip outside the plastic
will avoid relaxation effects.
Pat http://www.aquasite.com/skonkworks
