70-30 COPPER NICKEL PIPING AND 90-10 CU-NI FITTINGS
I work as QA SPECIALIST on US NAVY destroyers. The firemain and sea water piping was recently changed
from 90-10 copper nickel to 70-30 copper nickel but some of the fiittings are still 90-10 cu-ni as per the
drawings.The pipefitters in this shipyard have at different times installed valves backwards,strainers backwards,
and installed wrong material piping.
I think that by picking and choosing where you are going to use 90-10 fittings or 70-30 fittings there will be confusion and mistakes made.Is a 70-30 fitting that much more expensive than 90-10 fitting?
Any opinions out there on this? DON KUMPUNEN
RE: 70-30 COPPER NICKEL PIPING AND 90-10 CU-NI FITTINGS
Might have a bearing on the cost and selection.
rmw
DON KUMPUNEN
However, I can comment on the technical merits of your questions.
The thermal expansion of both metalurgies are the same at 9.5 X 10^-6 in/in/F, so there won't be undue stress on the braze joints with temperature changes.
The hardness of the 90/10 is Rb 30, compared to Rb 20 for 70/30, so the 90/10 will be more resistant to erosive wear in the elbows and any fittings subject to erosive flow patterns.
The ultimate strengths are the same, but the 70/30 has a higher yield than the 90/10.
I don't have a problem with it, however, I would refer your question back to whoever it was that initiated the change in the piping alloy or shipyard engineer, or someone with technical overview of the project.
rmw
The price on these alloys varies hour by hour. A month a go the 70-30 would have been higher due to the nickel content, but with what’s happening the metal business, especially copper at this time only a quote could give the price. Prices increases, surcharges, allotments and back orders are in place on every metal.
It is bad enough that a pipe supplier I'm acquainted with could sell his inventory of copper pipe at scrap prices and recover his investment.
A good website to monitor the nickel side of the metal market is.
www.marfas.com
