Is there anyone familiar with ASTM?
I am looking for the ASTM standard D3039 and D3158, both for plastic,
I think it should be somewhere in Vol: 08.02, but I just can not find it right now, I will use it in urgent.
If any of you have this standard, pls send it to me.
Xinrongding@hotmail.com
Thank you.
RE: Is there anyone familiar with ASTM?
ASTM D 3039/D 3039M [i]Standard Test Method for Tensile Properties of Polymer Matrix Composite Materials[i]
is in volume 15.03, or available at:
http://www.astm.org
ASTM D 3158-83 Specification for Asphalt Saturated and Coated Organic Felt Used in Roofing was withdrawn in 1983.
Cory
I found a problem, because I need dogbone samples for +45,-45 Twintex, what is the standard for dogbone specimen?
