IR thermografic beginner
I want to start IR thermografic inspection for ganeral applications with a cheap device,new or second hand.Do you have a tipp for me?It could be possible with a thermal filter?
Thank you
Thank you
RE: IR thermografic beginner
Thermography is an unregulated market so pretty much anyone can just buy a camera and begin doing inspections however if you want to be regarded as someone who provides quality thermographic surveys then you need to get properly trained, get a decent piece of kit and good software to produce the right sort of reports. Due to it not being regulated there are certain individuals operating without the correct parameters as mentioned above and so do not offer the right service and often produce false results and reports and therefore give thermography a bad name. My advice is to contact the ITC to arrange proper training and try to get the best equipment you can, I would suggest Flir as a a camera maker because they are simply the best on the market but they do come in many different forms.
Good luck
MB
Ti Thermal Imaging Ltd.
http://www.reliabilitydirect.com/tempproducts/FLIR-thermacam_et.htm
Training and certification is recommended:
http://www.infraredtraining.net/
http://www.thermalsolutions.org/
http://www.infraredtraining.com/
Good luck.
Kind regards,
Roy Gariepy
Maintenance and Reliability Dept.
Dorlastan Fibers LLC.
Goose Creek, South Carolina USA
