Equally spaced construction points
Is there a way to create specified number of construction points on an elaborate sketch and be equally spaced automatically? (as in a bolt hole pattern)
Thanks in advance
Enduro99
RE: Equally spaced construction points
Law Curves may give you that.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
You can use Transform and give a delta value and use Multiple copies to create the points. This will not add any parameters to keep them spaced as such. IF you sketch construction lines between the points you can add equal length and coincident constraints automatically.
Michael
