Need Help Finding A High Torque, Low Speed Gearmotor
I am looking for an AC gearmotor with a set output speed of anywhere in the range of 30-60 rpm.  I need to deliver somewhere between 150 to 200 ft-lbs (1800 to 2400 in-lbs) of torque at a set speed.
Our power service is 230V 3ph 60hz and price is an issue so I am most likely looking for 'off the shelf' components.  A 3hp motor at 1800 rpm and 40:1 gearbox combo would work just as well, but I would prefer a gearmotor combination.
Does anyone know of a good source for this?  A site with an online catalog of parts would be great.  Both gearmotor combos and separate components are fine.  Thanks.
Davey
RE: Need Help Finding A High Torque, Low Speed Gearmotor
For "off the shelf" items in this size range, try Minarik Automation & Control:
www.minarikcorp.com
BK
Suggestion: Visit
http://www.thomasregister.com
and type Gearmotors under Product or Service, which will return 132 companies to approach to
How many do you need?  If you just need one, buy it on Ebay.  I have purchased several at auction.  Big advantage, its probably in stock.
