BOM not updating...
BOM not updating...
BOM not updating...
I'm running 2004 SP2.1. I have a part with multiple configurations & a drawing. I'm using the bill of materials that is NOT an Excel spreadsheet. I have the AUTOMATIC UPDATE BOM toggled ON.
With the drawing open... I change the config in the view I used to insert the BOM. The BOM does not update to reflect the selected configuration. I have to select the Column Properties in the BOM & change configs there also. Can I tie the BOM to the drawing view so they both change together?
Utimately - when I'm done making parts & drawings - I want to open a drawing - select a config - print - close https://www.tipmaster.com/images/cheers.gif BORDER=0>
BTW - I have my VAR tech support working on this one too.
tatej usfilter.com
