Starting lisp from VBA
Hello
Ok everyone, got an easy one for you. I am about 1/4 of the way into rebuilding our whole AutoCAD menu system in VBA. Our programmer decided to go make more money somewhere else, So i am on a crash course in learning VBA. I am having to take some short cuts for right now. My question is if I can run a AutoCAD Lisp Routine from a VBA program and how.
RE: Starting lisp from VBA
This may help some
http://www.afralisp.com/vl/vl-vba1.htm
You can also run commands (lisp calls) from the command line in vb, but timing and usser interaction gets real hairy doing it that way.
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
Thank you for the replies
