Font plotting problems / conversion
Hello everyone. I had quit my job of 17 years and took up with another company a year ago. Everyone was hopelessly stuck in AutoCad R14. I have 2002 on my machine, and everything is fine EXCEPT:
Something is going on with our fonts. Letters such as "N" "M" and "V", the pointed angles of these letters are stretching beyond their intended distance. It's not making things illegible, but it does look kinda strange. This problem occurs ONLY ON THE PLOTS. You cannot see anything unusual on the screen.
When I start and finish a drawing myself in 2002, there is no problem. The problem arises when I edit older R14 dwgs. and then plot them out. The other drafters (planner and EIT) not what I would call drafters, use the simplex font. I have always used Romans.
Has anyone encountered this problem, and could it be fixed??
I have tried so many things, including matching properties to newer text. Nothing is working.
thanks in advance.
thanks in advance.
RE: Font plotting problems / conversion
All is well at the office and the boss is in a much better mood. Thanks a million!
