Multilouver fins
Multilouver fins
Multilouver fins
I have spent some time searching this issue and can't seem to locate any source with good information on copper multilouver fins.  One layer of these fins is attached on the outside to an aluminum cylinder that is internally heated.  I am trying to calculate the fin performace, convective coefficient and basically see if I can improve the cooling of the aluminum cylinder.  Any ifno would be greatly appreciated, or a source list, to some what accurately desribe these fins and flow (laminar, turbulent, transitional, etc).
RE: Multilouver fins
A recent article titled "Estimating The Effect Of Flow Bypass On Parallel Plate-Fin Heat Sink Performance" by
Robert E. Simons was published in http://www.electronics-cooling.com/html/2004_february_cc.html and the associated paper magazine.  This seems to answer your question.
Steve
You might want to look at the Wolverine tube site.  They have an "engineering data book" available in pdf format that discusses fin efficiencies and performance. The URL is: http://www.wlv.com/products/databook/databook.pdf
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
