Backwards compatability
Does anyone know if Inventor 8 is backwards compatible with Inventor 6?
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
RE: Backwards compatability
The only way you can read an IV 8 file in 6 is to export it to STEP or SAT. IV like most other solid modellers don't retain backwards compatability.
You will be able to read the step or sat, it will just be a dumb solid though with no feature retention.
Alan M. Etzkorn
Product Engineer
Nixon Tool Co.
www.nixontool.com
