Ref.dimension display problem in SW2003
Hi, all
I'm new on solidworks, and I'm using solidworks2003. I have a curious problem in solidworks derawings. I used to use reference dimension instead of insert dimension from the model. But all the dimensions I got always have a "RD#" below the numbers where # are numbers set by SW itself. I checked the help files and I can not find a way to remove it. Do anyone know how to do this?
Thanks in advance.
Thanks in advance.
RE: Ref.dimension display problem in SW2003
I can't give you the exact location as I have been away from SWX for 5 months now.
HTH,
Alan M. Etzkorn
Product Engineer
Nixon Tool Co.
www.nixontool.com
