looping ranges
looping ranges
looping ranges
I am new to VBA and Excel and can't figure out how to loop through ranges.  Basically, I have a calculation that takes two values (actually alot more but for example...) and returns one.  I want to input the two values from two ranges and output to another range.
'input variable values
rangeA = Range(RefEdit1.Text)
rangeB = Range(RefEdit1.Text)
'output location
rangeC = Range(RefEdit1.Text)
'then I need to start a loop
For Each cell In ???
        RangeC.Cell.Value = Function(rangeA.Cell.Value,rangeB.Cell.Value)
Next cell
Please help me with this syntax!!!  I think that I could figure it out with some example code but I have been having a hard time finding example code for this.
Rob
RE: looping ranges
Rob,
Not to sure what you mean. Why a loop if you only have 2 input values? If you want to create a table, it is much easier to call the function multiple times from the worksheet.
However, to come back to your question: you can loop through cells in basically two ways:
1. the "For each" construction:
CODE
Dim C As Range
For Each C in InputRange
   x = MyFunc(C.Value)
Next C
2. by using an index:
CODE
Dim i As Integer
For i = 1 to 10
   x = MyFunc(Cells(i,1).Value)
Next i
Cheers,
Joerd
RE: looping ranges
Joerd,
Thanks for the reply.  To clarify I am working with an equation of state.  I want to input Temperature and Volume and get back Pressure.  I want to do this for an entire range of temperatures, volumes and output Pressure to a range in the spreadsheet.
You showed a case where there is a single variable and I understand that.  However,  I need to learn how to work with  mulitple ranges.
So I have something like the following:
Dim temperatureRange As Range
Dim volumeRange As Range
Dim outputRange As Range
temperatureRange = Range(RefEdit1.Text)
volumeRange = Range(RefEdit1.Text)
'output location
outputRange = Range(RefEdit1.Text)
For each ?temperatureRange and volumeRange and outputRange?
outputRange.Value = Myfunction(temperatureRange.Value,volumeRange.Value)
next ?temperatureRange and volumeRange and outputRange?
How do I tell VBA to use the cooresponding value of temperature, volume and output.  This should be simple but I can't find it anywhere I look.
Rob
RE: looping ranges
Ok, further to my previous statements, let's assume you have 3 columns: TemperatureRange, VolumeRange and OutputRange. You can use the .Offset(row, column) method, or directly index the range (which is a little easier to understand). So, for example:
For i = 1 to TemperatureRange.Rows.Count
   OutputRange(i,1)=EOSFunc(TemperatureRange(i,1) , VolumeRange(i,1) )
Next i
By the way, I still fail to see why you wouldn't just fill up your OutputRange cells with the formula =EOSFunc(TemperatureRange, VolumeRange). As mogens taught me in an earlier thread (Thread770-75114), you could even use named ranges in this case (so name your range with temperatures TemperatureRange, etc.)
Cheers,
Joerd
RE: looping ranges
That is just what I needed.  Thanks for the information!
Rob
