Center of Gravity.
Center of Gravity.
Center of Gravity.
How can I find the center of gravity for a drawn shape in AutoCad?
RE: Center of Gravity.
Create a region usion REGION command, select boundary of shape.  Type MASSPROP and select region, it will give you x & y coordinates of centroid.
CarLB
I followed your instruction.  However, my x & y value are based on an origine that I don't know.  How do I find the origine for these values.
Thanks.
CarLB
Thanks I found out the way to do it.
