An Autolisp Lesson part 4 the legend continues.....
ok well then 2 things to talk about this time but first i want to say thanks to tigrek and striker cause im learning so much if i could i'd give you both 3 stars
ok well im ready to edit the linelength.lsp one more time. this time i want and need to do a couple of things. 1 set up so that when it lables its readable down & right. also i want to semi incorperate another lsp in this one to allow me to append and prefix each lable.And for all the settings i would like them to either default to a perticular setting or assume the last option the default unless otherwise changed. i think that this would be the most used part i would use!!!
as for the append/Precede lsp here is the code i called the lisp ADD2TXT.lsp
(defun c:addtxt()
(setq count 0)
(setq txt_t_add (getstring T "\nEnter additional text: "))
(initget "A P")
(setq AP (getkword "\nAppend/<Precede>: "))
(princ "Select text: ")
(setq txtset (ssget '((0 . "TEXT"))))
(repeat (sslength txtset)
(setq txt1 (entget (ssname txtset count))
txt2 (assoc 1 txt1)
txt (cdr txt2)
); end setquote
(cond
((= AP "P" )(setq newstrng (strcat txt_t_add txt)))
((= AP "A")(setq newstrng (strcat txt txt_t_add)))
((null AP)(setq newstrng (strcat txt_t_add txt)))
);end cond
(setq nwtxtent (subst (cons 1 newstrng) txt2 txt1))
(ENTMOD nwtxtent)
(setq count (+ count 1))
);end repeat
ok now i just need to know at what point to tell it to use this command in our linelength.lsp
Also i have an object # lsp that supposedly uses #'s Letter's to kinda lable things but i would like to set it so it does either eddits text and adds a # to the end or a letter and then cycles thru a given sequence like say i only want it to go 1-10 or A-D/L/Z but have some kind of a way to specify and set defauls like i was talking about in the previous
PS tigrek
i agree with you on the text rotation its not really that important but say if you were aligning something with something it would probably be a good idea to know but i have sill yet to get the snipit to work later in this thread ill post the code with it set like that and show the errors i got
later guys gotta go home and fix the sink
(defun c:addtxt()
(setq count 0)
(initget "A P")
txt2 (assoc 1 txt1)
txt (cdr txt2)
); end setquote
(cond
);end cond
(ENTMOD nwtxtent)
);end repeat
PS tigrek
if everyone helps everybody the world will be a better place
RE: An Autolisp Lesson part 4 the legend continues.....
