Globe Valve Trim
Globe Valve Trim
Globe Valve Trim
I'm trying to select temperature control valves to meet a mechanical engineer's Division 15 spec.  He has specified globe valves with cage type trim.  I've never seen this in a spec before.  What is the advantage in a commercial temperature control application?  Who makes a globe valve with cage type trim?
RE: Globe Valve Trim
Look at these:
1. http://www.koso.co.jp/e/v_glo.html#501G
2. http://www.ccivalve.com/pdf/241.pdf
3.http://www.yamatake.com/products/industrial_automation/control_valves/ss/SS2-ALV100-0100.pdf
Hope this helps!
